903 cylinder
  • bangshift440rt
  • bangshift440rt's Avatar Topic Author
903 cylinder
03 Apr 2006 23:57
#36593
i am rebuilding my engine, is 70 mm is the maximum overbore for the 903 block correct? i would like to install a 12.5:1 engine kit 1015 cc's
  • wireman
  • wireman's Avatar
Re: 903 cylinder
04 Apr 2006 00:14
#36596
that is the maximum with stock sleeves.if you are splitting the cases id suggest finding a 1015 cylinder block and boring it to 1075 with 10.25:1 pistons.this way you can use these pistons in another motor easily the 1015 pistons are going to limit you to very thin 900 sleeves or a standard bore 1015.the extra cubes with the 1075 kit will gain you more horsepower plus you will not have as hard of a time finding fuel with the lower compression.B) goodluck,happy wrenching!
  • bangshift440rt
Re: 903 cylinder
05 Apr 2006 23:50
#37152
thanks for the help. now.... to find that 1015 cylinder. if anybody has one they would like to sell or trade for some z stuff or even car stuff... pm me. thanks
  • wireman
  • wireman's Avatar
Re: 903 cylinder
06 Apr 2006 05:01
#37173
let me do some digging,where are you located?;) goodluck,happy wrenching!
  • bob_z1
  • bob_z1's Avatar
Re: 903 cylinder
06 Apr 2006 13:56
#37280
you want a 1015 cyl to bore? I have one that needs bored, 1075 will clean it up... $10 + postage.
also have a 1015 with pistons, not sure but look to be about 13 to 1 compression.
later! Bob
  • bangshift440rt
Re: 903 cylinder
10 Apr 2006 00:54
#38242
i am also in pa, what area are you in?
+what brand are the pistons?
  • donthekawguy
  • donthekawguy's Avatar
Re: 903 cylinder
10 Apr 2006 05:09
#38249
If your looking for a set of 1075 look up suicycle in Nampa Idaho. Last year they had a set of new Weisco 1075's for $300. They might still have them laying around.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
