best way to do an oil cooler- gpz oil pan?
- Trav
03 Apr 2006 18:54
I want (actaully I probably NEED) to add an oil cooler, as I am sticking in a wiseco 615cc kit in my 550. The GPz's all have stock oil coolers that come off the pan at the front between #2 and #3 risers, and the GPz550 is basically the same block, so the pan should bolt right up and the oil cooler should function properly, correct? I would probably try to use a larger than stock heat exchanger though.
I don't even know if it is possible with a 550, but I know with other engines (900/1000, 650) an oil cooler can be added off of the pump outlet by being tapped into at other locations in the block.. is this more desireable? Or just the easiet/only way to do it on those bikes, and really makes no difference as far as function goes?
Thanks! Any insight would be great.
- RetroRiceRocketRider
Re: best way to do an oil cooler- gpz oil pan?
03 Apr 2006 19:00
I'm adding the OEM cooler and oil pan from an '82 GPz750 to my '78 KZ650. They both used the same oil pan gasket and o-rings, and it will look and (hopefully) function better than the Lockhart cooler I have on there now.
You should be able to use the cooler and oil pan from either the '82/'83 KZ550 GPZ models or the '84/'85 ZX550 GPz models. You could check on the Kawi website to make certain that they use the same gasket and o-rings as your bike does to pretty much gaurantee it fitting.
Post edited by: RetroRiceRocketRider, at: 2006/04/03 22:01
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- Trav
04 Apr 2006 20:54
Alright, thanks. I was pretty positive of this stuff, but it had been awhile and I wanted to make sure.
I saw your other post in response to the other guy adding an oil cooler, and saw the part about the relief valve. I will have to check, but I assume the 550 would have one as well. This is something I have to add with the oil pan swap, and fits right in with no modification to the exisiting parts?
