How much oil does this thing require?
- Fozzie
03 May 2010 16:15 #365267
by Fozzie
1982 KZ1000J
How much oil does this thing require? was created by Fozzie
Ok I know...such a Noobious question. But how much do the KZ1000J's take? I have four quarts but not sure how many to feed the ol gal.
1982 KZ1000J
- muddy1
- 1980 Kz1000 LTD B4
03 May 2010 16:21 #365269
by muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
Replied by muddy1 on topic How much oil does this thing require?
it should say the capacity on or near the filler cap, mine takes 3.8L, I beleive that's 4.2 quarts, do not just dump four quarts in the thing, these bikes hide oil and you will end up overfilling the crank case. I would add three quarts, put it on the centerstand and check your sight glass. :lol:
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- Fozzie
03 May 2010 16:27 #365272
by Fozzie
1982 KZ1000J
Replied by Fozzie on topic How much oil does this thing require?
And it should fill the sight glass halfway? Or all the way up? Sorry man, I really am new to bikes lol.
1982 KZ1000J
- TeK9iNe
- What did you do!?!
- Thank you received: 28
03 May 2010 16:28 #365273
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic How much oil does this thing require?
Just use the sight glass and keep it between the lines (middle of glass is safe). On the centre stand of course.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Fozzie
03 May 2010 16:30 #365274
by Fozzie
1982 KZ1000J
ARite thanks about to go change her up now. Oh, Tek, the carbs were just clogged up, cleaned em up and shes running great now. Thanks for all the advice
1982 KZ1000J
- trianglelaguna
- Thank you received: 235
03 May 2010 16:48 #365276
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic How much oil does this thing require?
did you change the filter too???
it will need to turn over or run a second or two...then settle again if you did change the filter too...the window will drop some after it fills the 1/4-3/8 qt the filter chamber holds...much better to fill just shy of the level line on the window and run,,-top off the full window line,,,-repeat-....till looking just right...then ride it for a few park it and let it settle with bike level and on level ground for a 1/2 hr...too much is a drag and can spew out and take a drain even to get right...
1976 KZ900
2003 ZX12R
2007 FZ1000
