Oil coolers
- Seen172
This is the fitting on the back of the pan
And here is the other
Are those a stock type piece? Can I just plug those two points with another solid plug? Will it hurt to plug them? I just don't know... Keep the cooler or not?
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- bountyhunter
- Thank you received: 337
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- Seen172
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- Polar_Bus
- Thank you received: 7
Bikes:
'84 GPz1100
'06 HD Fatboy
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Seen172
- BSKZ650
I'm trying to figure out a way to plug them. I don't like the way I have to route the line so close to the exhaust. Last thing I want is to be stuck between Salt Lake City and Wendover from a burned through oil line... I cant find any solid replacements for these, do you think I will be able to clean them and scuff them and throw some JB Weld to close them up?
The last thing I want to trust is JB weld to secure a oil passage.
look at some stainless steel braded lines, earls makes them and you can prob find the stuff at a custom hot rod shop or spec, hose place.
my 1000 has the lines run up under the tank and then to the cooler, they do kind of get close to the header but I have never had any issues.
If your bound and dertermined to plug them off, you can cut the line close to the fitting, shove a bolt in the line and secure it with a couple of hose clamps
- hugo
- '92 Zephyr 750
- Thank you received: 71
I have a '91 Zephyr 750 oil pan available with the oil lines and the rear gallery plugged. If you are interested, drop me a line.
- Seen172
Thanks for all the awesome advice! I think for now I'm going to cut them short and shove a bolt in there.
