Higher comp ratio = ignition retard?
- BARNEYHYPHEN
03 Apr 2006 13:06
1976 Kz900 cases with new 1015 block honed to 70.25mm. Resultant compression ratio increase from 8:1 to 10:1. It has been suggested I should retard the ignition some due to the increase in comp ratio?
Any thoughts on ho much retard might be required? Thanks.
- oldkaw79
Re: Higher comp ratio = ignition retard?
03 Apr 2006 14:21
You will have no problems at all. Set it to factory specs and enjoy the ride.
- RomSpaceKnight
- wireman
03 Apr 2006 16:41
as long as it doesnt ping on the gas you get, run it.no 2 bikes are going to run exactly the same it depends on your combination of parts and how its put together.:whistle: goodluck,happy wrenching!
- BARNEYHYPHEN
05 Apr 2006 10:46
Thanks everyone. I'll sync the casrbs tonight and see how she runs.
