Dragbike Engine for Street Use?
- supercharged
30 Apr 2010 14:13 #364493
by supercharged
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
Dragbike Engine for Street Use? was created by supercharged
I know some of you have big bore bikes and even drag race them... I have an opportunity to acquire a 1400+cc dragbike, but I don't care for to race it.
What are the chances that I could use this engine on the street? I know overheating will be the first issue, and possibly the need for race fuel, but should I even consider this??
I do have a 1200 bigblock and for the amount of riding I do, this does ok for the street.
Any input would be appreciated.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- otakar
30 Apr 2010 14:34 #364496
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Dragbike Engine for Street Use?
It's not the size that might be a problem, it will be the fact that it most likely has 12.5:1 or higher compression and the cams will be un-tamable. If you install a set of reasonable cams and run aviation gas you would be OK.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- irishwill
- Thank you received: 6
30 Apr 2010 14:41 #364497
by irishwill
Replied by irishwill on topic Dragbike Engine for Street Use?
if your gonna run it from your house to the local hang out once a week...maybe
but if you plan to ride it....I would not do it.
You could de-tune it enough that it would live....but then what would be the point of having a 1400cc motor?
personally I think you would be further ahead with your 1200 motor with a ported head and cams....keep the compression reasonable and you'd still have a hotrod motor.
just my .02
just my .02
- racer54
- Thank you received: 114
30 Apr 2010 14:58 #364500
by racer54
Replied by racer54 on topic Dragbike Engine for Street Use?
What they said. You also have to remember that depending on which cams are in the motor, you can only go smaller in the cam department to a point and then you would have to change lots of things to run smaller "street" cams. Overall, I think the motor you have would be better for day to day use although that 1400 motor would make life interesting!
- supercharged
30 Apr 2010 15:05 #364502
by supercharged
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
Replied by supercharged on topic Dragbike Engine for Street Use?
Thanks!
Didn't really think of the cams. That is why I like to share 'ideas.'
I will continue to use the 1200, but if the opportunity is real, I may pick up the 1400 and build a street"able" bike around it. It may be to wild for more than a show and short ride here and there, but I do like the interesting part.
Any ideas if the electric starter would turn an engine that size (compression)? I do OK with the 1200.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- mark1122
- Keep twisting it
- Thank you received: 109
30 Apr 2010 15:10 #364507
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Dragbike Engine for Street Use?
i used a honda starter on my 1327cc, no problems.
a smaller port head would be more fun on the street with the 1400 too.:woohoo:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- racer54
30 Apr 2010 15:15 #364509
by racer54
Normally, that size of motor along with any compression would tax the stock starter quite a bit. I have heard of guys doing just what you are thinking without any problems though. Couple options are some guys wire in a second battery for just the starter but some say it shortens the life of the starter and some say it doesn't...? Another option is there is a guy down south somewhere...I think I have his address...that rebuilds stock starters to put out more power for just this type of situation. They aren't cheap but I hear they have no problem with motors like that one. Lots of guys are using it on self-start dragbikes with motors like the one you are thinking about. Option 3 is to exercise the hell out of your right leg and kick start that bad boy!
- supercharged
30 Apr 2010 18:55 #364568
by supercharged
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
mark1122 wrote:
Mark - Are you still running the big block, or did you revert back to a smaller engine? I know some time ago you were thinking of removing the big block. What was you biggest concern?
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- mark1122
- Keep twisting it
30 Apr 2010 19:14 #364575
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
i bought the big block used. as it turned out , it was worn more than i had hoped and burned oil. so i rebuilt with a new mtc 1200cc. it ran hot. it hit 250* oil temp,in mid 70's weather.
i know a local guy who has run a 1428 10:1 on the street, for years.he kick starts, but i;m sure the honda starter would be fine with 10:1 pistons. my 1327 started right away every time, so does my 1200. i think u could run the 1400 as long as u stay out of the city traffic.
he runs something like a 33mm rs/tm gxr carb? not sure how big his ports and cams are? he hasnt run it for a few years.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
