- Thank you received: 2098
many things needed as far as tuning on a KZ550A1.
02 May 2010 08:17 - 02 May 2010 08:18 #364957
by Patton
Replied by Patton on topic many things needed as far as tuning on a KZ550A1.
Sometimes petcock issue may be resolved by: remove from tank, disassemble, clean, reassemble, and reattach to tank.
If needed, Z1E carries petcock rebuild kit.
Click > Rebuild Kit
There's an exploded view parts diagram on kawasaki.com included in the fuel tank diagram.
Click > Rebuild Kit
Last edit: 02 May 2010 08:18 by Patton.
- gutter
02 May 2010 10:45 #364998
by gutter
Replied by gutter on topic many things needed as far as tuning on a KZ550A1.
Is the filler cap check valved so only air in but not out?
- loudhvx
- Thank you received: 1616
02 May 2010 11:39 #365006
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic many things needed as far as tuning on a KZ550A1.
gutter wrote:
I don't think so (but not absolutely sure), otherwise you would get a pressurized gas tank parked on a hot day. Some cars may do that, but I've never noticed it on the bike.
1981 KZ550 D1 gpz.
Other links.
02 May 2010 11:53 #365011
by Patton
gutter wrote:
Thinking no check valve; just a circuitous channel designed within the cap to allow air movement both in and out which keeps pressure inside tank equalized with the outside atmospheric pressure.
Like holding finger over top end of a full drinking straw retains liquid inside straw until finger is released opening the top end to atmospheric pressure and fluid runs out of straw. Clear vent in fuel cap keeps finger away from the straw.
Without fuel tank venting from inside to out, undesirable pressure could build up inside the tank due to becoming heated from sitting in the sun.
Wasn't this as explained by Mr. Nye, The Science Guy? :laugh:
- gutter
16 May 2010 18:26 #368394
by gutter
OK. The bike's running AWESOME!!
First thing, I just didn't plain have enough gas to bring it above the "ON" port. I filled the tank full and it worked fine.
Then I got a decent timing light and set my timing. And got a set of sync gauges.
Syncing did the trick!! I had one carb off by 2-3 (inches) ticks on the gauge. Adjusted and all was perfect. Wow this thing got some balls now. I got a front tire on the way and a new tach cable. My fiance just got her temps so it'll be her little bike. That's the only reason I got it all tuned up.
Had it just been for me, I probably would have half-assed it a little. haha. And I'll get some pics up soon.
- hocbj23
- Visitor
16 May 2010 18:36 #368395
by hocbj23
Replied by hocbj23 on topic many things needed as far as tuning on a KZ550A1.
One final step might be to invest in a good in-line fuel filter.Might save u grief down the line.bj
- gutter
16 May 2010 18:45 #368396
by gutter
Well, I had bought a cheap paper one, but it was hard to fit under the gas tank and it didn't seem to allow the fuel to flow right. It had to loop around and flow uphill a little. I thought that was causing some issues. Then I see the one's on Z1's site. They look like a small copper air muffler on a pneumatic valve.
- Tony
- Thank you received: 13
16 May 2010 18:51 #368398
by Tony
Replied by Tony on topic many things needed as far as tuning on a KZ550A1.
...running out of gas, it makes it quit every time.
The kz550 is an awesome bike. I wish I hadn't sold mine. My daughter wants to ride and that would be the perfect bike for her.
