small bolts on each end of cylinder head
- zfighter
27 Apr 2010 20:11 #363737
by zfighter
small bolts on each end of cylinder head was created by zfighter
Hey guys I am just wondering how important those small 10 mm bolts found on each end of the cylinder head are. there is 4 studs per cylinder but then there are the little bolts on the end of the head where the dowels are. the reason I ask is well one snapped off in the block, and well no problem drill it out, well it wouldnt be a problem if my cheap china drill bit wouldnt have snapped off in the hole. so I tq the studs to spec, should I have anything to worry about
thanks
thanks
- PLUMMEN
- Thank you received: 104
27 Apr 2010 20:18 #363742
by PLUMMEN
Replied by PLUMMEN on topic small bolts on each end of cylinder head
probably not a problem for most,but i have really bad luck bypassing things like that myself!
- Mcdroid
- Gone Kwackers
- Thank you received: 317
27 Apr 2010 21:50 #363760
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic small bolts on each end of cylinder head
Well, if they weren't important, Mother Kawasaki wouldn't have designed and placed them there. On my 1100, the PO stripped one of these bolts...I took the time to drill it out and TimeSert it.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
- Thank you received: 337
27 Apr 2010 22:50 #363770
by bountyhunter
Replied by bountyhunter on topic small bolts on each end of cylinder head
The 10mm bolts going up into the head on the 750 twin are REALLY important: they keep the head gasket from oozing oil at the front and back...... guess how I learned that.:laugh:
