Valve Guides
- WMKZ900
27 Apr 2010 08:24 #363543
by WMKZ900
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
06 Kawasaki Concours
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
Valve Guides was created by WMKZ900
My valve seals are well worn, so I intend to replace them.
Should the valves or valve guides be replaced also?
Will a "automotive type", a standard valve spring compression tool fit the Z1 head?
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
- timebomb33
- Thank you received: 10
27 Apr 2010 08:41 #363546
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Valve Guides
if the guides are worn then yes, replace. a standard automotive valve spring compressor wont work you engine uses recessed spring pockets a standard compressor cant get in to them with out being modified.
- bountyhunter
- Thank you received: 337
27 Apr 2010 11:02 #363576
by bountyhunter
Replied by bountyhunter on topic Valve Guides
I had 75k miles on mine when I rebuilt it and every one of the guides measured out to new spec. The machinist told me the guides don't wear unless the valve stem has side torque on it which shouldn't happen if they are set up right.
I bought a full set of new guides and din't need a single one.
- WMKZ900
27 Apr 2010 12:07 #363594
by WMKZ900
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
Replied by WMKZ900 on topic Valve Guides
To my knowledge, my 76 Kz900 has approximatly 40k miles. As far as I know, the head has never been off. I appreciate the input and may get into replacing the valve seals soon.
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
- Link14
- Thank you received: 6
27 Apr 2010 12:36 #363598
by Link14
Replied by Link14 on topic Valve Guides
When I sent my head (34k miles)to the machine shop, part of the cost per valve was measuring all of the components. Of the 8 valves, two of the exhaust guides needed replacement. One of the valve had bent and the other was sticking so much that he recommended replacing.
Once the heads apart, check all the measurements before ordering parts....saves on time and shipping. (Ask me how I know this...
- larrycavan
- Visitor
27 Apr 2010 14:45 #363626
by larrycavan
Replied by larrycavan on topic Valve Guides
WMKZ900 wrote:
Check the vave stems as well.
If a .276" solid pilot drops all the way into the guide. Replace it.
Check Ebay for spring compressors. I just picked on up for those small valve ATV heads for $30 with 3 adapters & it adjusts on both ends...which is pretty cool!
