Anyone reuse valve springs on kz1000?
- cruspeed
Has anyone had there valve springs checked and they were bad? It's not that I don't want to get them but I don't want to spend money that I really don't need to.
78 KZ1000 project X 2
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- testarossa
- Thank you received: 82
kzrider.com/index.php?option=com_kunena&...it=20&limitstart=180
It should take you to page 10, where I came up with a super simple method to check compression at a specified lenght. If anything doesn't make sense, then I'll be happy to talk you through the process. Heck my bike is a '78 so the numbers are all the same.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Go new, and be at peace
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- APE Jay
- Banned
- Thank you received: 58
When in doubt, throw it out!
Valve springs should be considered an expendable item like used piston rings, gaskets, etc.
- kawsakiman
- Thank you received: 6
- larrycavan
- Visitor
Even new springs are often not close to equal out of the package. You might be quite surprised how far off a brand new set of springs will be from spring to spring.
It's a crap shoot on any given day when you open a package. Sometimes they're not bad and sometimes you shake your head and wonder why they're not checked before they go in the package.
I recently had a set of new .500 lift springs that I couldn't even use 2 of them because the required .060" worth of shims to get the seat pressure right. That pushed them too close to coil bind over the nose.
I've never had stock springs that far off. Even very old ones.
If the cams are stock and the springs can be shimmed with thin shims to bring them into spec. Run 'em
- PLUMMEN
- Thank you received: 104
what he said!For starters, the old springs are often fine but need shims to get the seat & nose pressure correct after a valve job.
- cruspeed
