APE Cam Chain Tensioner adjustment
- hocbj23
- Visitor
26 Apr 2010 13:10 #363316
by hocbj23
APE Cam Chain Tensioner adjustment was created by hocbj23
OK, like so many others I am going to install an APE cam chain tensioner on the KZ 1000. No problems getting the old one off or the new one on. Question is: How do u properly adjust it for the correct tension WITHOUT taking the head off.I have heard all sorts of suggestions from as tight as u can get it in with ur fingers and then back off an 1/8 or 1/4 or 1/2 turn to as tight as u can get it and leave it that way,etc. I have no tech spec on the spring tension of the old "automatic" tensioner so I am a bit lost here.Anybody?Thanks much.bj
- otakar
26 Apr 2010 13:24 - 26 Apr 2010 13:25 #363317
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic APE Cam Chain Tensioner adjustment
The best thing to do is to call APE and they will tell you the exact procedure. On here there are as many procedures as there are opinions. there must be a hundred threads on here telling you how to do it and there are a hundred procedures.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Apr 2010 13:25 by otakar.
- otakar
26 Apr 2010 13:28 - 26 Apr 2010 13:28 #363318
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Here is the most recent thread.
kzrider.com/index.php?option=com_kunena&...d=2&id=358484#358845
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Apr 2010 13:28 by otakar.
- hocbj23
- Visitor
26 Apr 2010 14:06 #363321
by hocbj23
Replied by hocbj23 on topic APE Cam Chain Tensioner adjustment
Thank u sir.Since I have heard motor at #1 tdc, turn tensioner in until contact,back out 1/4 turn, more than once, I will start there.appreciate it.bj
- otakar
26 Apr 2010 14:29 #363329
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
When APE states "until contact" this means "tighten" with your fingertips. I had to call them to confirm this. Than back off 1/4 turn. You can put any two cylinders at TDC. This is only to take any load from the chain.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- hocbj23
- Visitor
26 Apr 2010 16:04 #363361
by hocbj23
I understand.The stock "automatic" tensioner is running some level of pressure against the guide so I felt hand tight was what was inferred.Thanks.bj
