cam advice
  • larrycavan
  • larrycavan's Avatar
Re: cam advice
27 Apr 2010 14:50
#363628
toad wrote:
thanks for all the insight.It sounds like the most affordable upgrade would be the gpz1100 (83-85) cams,slot my stock sprockets and check everything for fit.That would mean electronic tach as well correct..I just torqued down the head last night, I may have to wait on the cam selection until money permits but at least I know what to look out for now. cheers.
They'll work but doing the sprockets up is not a 5 minute job.
It will be easier to go with KZ cams than the GPz cams. Just so you know it's not a 5 minute swap.
Keep an eye open and you'll probably find some Web 118's or Andrews 2x that would be easier to fit.
  • otakar
  • otakar's Avatar
Re: cam advice
27 Apr 2010 15:07 - 27 Apr 2010 15:08
#363633
Didn't Jay say that he had a set of sprockets for that conversion? Or did I misunderstand? I might even have a set of those cams.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 27 Apr 2010 15:08 by otakar.
  • toad
  • toad's Avatar Topic Author
Re: cam advice
28 Apr 2010 05:57 - 28 Apr 2010 06:00
#363796
ya I have been trying to keep an eye open for those cams for a while now but no success.If I don't find something this summer I will probably fork out the cash for new this fall,I have already blew all my money on the top end and still don't have rear brakes for my gsxr rear,oh well the front works though:silly: .
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Last edit: 28 Apr 2010 06:00 by toad.
  • Kraz1
  • Kraz1's Avatar
  • otakar
  • otakar's Avatar
Re: Cam Motion
28 Apr 2010 09:49
#363836
I took a look at the sprockets from APE they are ONLY for the MKII crank to GPz cam adaptation. so these sprockets will not work with the 1978 and earlier bikes.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
