kz200 service manual engine overheating etc
- fiendlybrds
25 Apr 2010 21:35 #363213
by fiendlybrds
kz200 service manual engine overheating etc was created by fiendlybrds
Hey all, on about a 60 mile ride i noticed a DRASTIC loss of power intermittently. i would be able to go about 65-70 on my kz200 for a few miles, then as soon as a hill came up, it would struggle like i have never experienced. couldn't get it to go over 50 at that point. i would pull over, let it cool off, and it would be good again...for a bit.
again this morning i was having this problem, but this time more frequently and drastically. until i jsut said that it was unsafe to drive, and it would not go any longer.
another weird side note, there is this fine red dust all over, (even inside the points cover) that was not there before. almost like rust dust, not sure though.
any ideas, or a proper service manual for my bike would be appreciated.
tl;dr kz200 over heating- loss of power, possible timing issue? clutch? troubleshooting tips?
thanks -joe
thanks -joe
- loudhvx
- Thank you received: 1616
27 Apr 2010 03:54 - 27 Apr 2010 03:55 #363476
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic kz200 service manual engine overheating etc
here's a kz200 manual
home.comcast.net/~loudgpz/KawKZ200Man.pdf
I'll only be able to host it temporarily.
1981 KZ550 D1 gpz.
Other links.
Last edit: 27 Apr 2010 03:55 by loudhvx.
- Thank you received: 2098
27 Apr 2010 04:19 #363482
by Patton
Replied by Patton on topic kz200 service manual engine overheating etc
Might be fuel starvation due to vapor lock resulting from obstructed vent in fuel tank cap. Could test run with fuel cap ajar (not snapped down), to determine whether obstructed vent is an issue.
There are also other reasons which can cause impaired fuel flow resulting in fuel starvation, such as clogged petcock or clogged in-line fuel filter, crud inside fuel tank, etc.
- JR
- Thank you received: 448
27 Apr 2010 12:48 #363603
by JR
Replied by JR on topic kz200 service manual engine overheating etc
Is there possibly a cylinder head or crankcase breather which might be plugged ?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
27 Apr 2010 16:02 #363642
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic kz200 service manual engine overheating etc
Patton wrote:
For sure...
Make certain float bowls are filling completely!
Use the "clear tube" method to measure fuel height.
GL!
For sure...
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
