Sealing options for head/cylinder/base gaskets?
- beefsquasher
The gasket kit I bought came with 4 large o-rings for the base of each cylinder sleeve. I can't see how these will fit. There is a tiny little groove there, but these will not fit into it at all, and it seems that the paper base gasket will do a plenty fine job anyway.
I have a 1075cc kit and am using a one-piece Wiseco head gasket. Do I still use the cam chain tunnel o-ring or just leave it out?
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- bountyhunter
- Thank you received: 337
As for the large O rings that go around the base of the cylinder tubes: mine had them too, not exactly sure why they are needed if the base gasket does it's job. But they do use them.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- APE Jay
- Banned
- Thank you received: 58
- keith1
- Thank you received: 2
Ready to put the top end back on the '77 KZ1000 and I have a few questions about sealing it up.
-Dave
i would use the large orings.....the orange are the cheaper ones...the black ones are better.....just push them up as high as they will go....if you try to roll them, they like to unroll.....fill the oring groove with
black rtv ...i put it in and try to scrape off excess with a razorblade and let it set up a day....rtv is room temp vulcanization...it needs a little time to firm up....dont go bannanas with that stuff.....dont ask me how i know!!:laugh: .....
- beefsquasher
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
