New cams
- customkz1000
24 Apr 2010 07:01 - 24 Apr 2010 07:06 #362794
by customkz1000
New cams was created by customkz1000
I'm rebuilding my Kz 1000 and I need to know how many horses I can get by putting 2x cams in and having the head shaved
Last edit: 24 Apr 2010 07:06 by customkz1000.
- mark1122
- Keep twisting it
- Thank you received: 109
24 Apr 2010 07:30 - 24 Apr 2010 07:31 #362796
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic New cams
u will have to be very careful with this task Luke.
Go not, where u have no knowledge.
if u mill the head the valves will get closer to the piston.
if u use larger cams to valves will get closer to the pistons, and valve to valve.
High compression pistons have the valve pockets pre cut to allow for these things, but u must always measure.
u should maintain a min clearance of .080" int., .060" ext. from piston to valve.
new pistons are the better path Luke. u will gain cc's as well.
No point putting a lot of money into upgrades without improving the breathing. Porting allows it to breath better.
Contact Larry Cavanaugh for support hear.
www.flowbenchtech.com/porting/CRH/index.htm
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 24 Apr 2010 07:31 by mark1122.
- larrycavan
- Visitor
24 Apr 2010 15:36 #362885
by larrycavan
Replied by larrycavan on topic New cams
customkz1000 wrote:
Mill the head just enough to make it flat and no more. Those cams will make a noticable difference for you. Tune it right and you could pick up 8-10 Peak HP.
You can put them right in on stock srockets and they'll work just fine. You'l get more peak torque if you pull them to 106 centers but if you're not experienced at degreeing the cams, then just bolt them in with stock sprockets.
Grind the X's out of the valve cover to be safe. It's just good practice to get them out of there.
