Break In
- larrycavan
- Visitor
Prep the block correctly.
Wipe out any excess oil in the cylinder bores before you install the head using good paper towels. It's just going to blow out the exhaust valve and start the process of carbon build up that much quicker.
- Buda
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- bountyhunter
- Thank you received: 337
Me too... and it smoked for about the first ten minutes after I fired it up.:laugh:Thanks Larry..I did use quite a lot of oil in the cylinders whin we were sliding the block over the pistons.
Tom
- larrycavan
- Visitor
Tom
Tom,
Make sure to get on the head retorque after you heat cycle the engine the first time. Let it get stone cold, then go over all the head fasteners again.
Ride Safe
- Thank you received: 2829
"Make sure to get on the head retorque after you heat cycle the engine the first time. Let it get stone cold, then go over all the head fasteners again. "
Larry, a question I've seen here many times relates to this process but I'm not sure I've seen a difinitive answer. Do you loosen all bolts before retorquing, loosen them one at a time as you retorque each one, or not loosen them at all and simply apply the torue again to ensure they are still in spec? Thanks, Ed
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- fordtruck
- Thank you received: 6
'77 KZ1000-MTC 1075 kit. Stage 1 port
- TeK9iNe
- What did you do!?!
Let it warm up by riding around for 5 min varying the throttle lots and poping it at lights.
Then I blow the snot out of her for about 50 miles in town!
HARD. HURRY, HARD! :laugh: :laugh: :laugh:
Then get back and drop that oil like its hot! (Cause it frikken is!)
Dump in Amsoil 20W50 Motorcycle, and off ya go.
I've done this to 20+ Bikes, and every one is still ploughing along great!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- larrycavan
- Visitor
Personally, I assemble all the fasteners with lube on them so I don't loosen them back up again.
Put some oil inside the nuts and on the stud threads. Just a drop or two to coat the threads. Don't fill the nut with oil or anything like that.
Put a thin film of assembly grease on washers and a drop of oil on the bottom of the nuts. Everything spins nice & easy.
When it's time to go over the nuts again, I set the torque wrench to max torque setting I'm using and follow the torque sequence.
The trick is to get to those head nuts after the first heat cycle.
- 9am53
- homebrew, and some bbq
BTW, thanks for the cams Larry, I love 'em
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Old Man Rock
- Thank you received: 225
First run, rpm up and down to seat the rings...
Take her home and let her FULLY cool down.
Re-torque ALL engine bolts and also frame engine mounting bolts if the engine was removed for rebuild.
After 50 miles or so, change out oil and oil filter!
This is a must for you had cam pre-lube and will have metal shavings/dust down in the pan now...
At 500 miles, check your cam to shim clearances... Adjust (shim swap) as required.
At 1500 miles, check valve clearances again.... If desired, now you can switch to synthetic oils... If doing so, replace oil and filter...
This is what I learned off Plum and Larry, you follow this and you'll be golden...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- 9am53
'84 GPz900r
'71 CB350
