How to tell if engine has been bored out.
  • jimstan
  • jimstan's Avatar Topic Author
22 Apr 2010 16:26
#362451
I have very little history on what engine work was done to
to my 1975 Z1B.
So my question is how can I tell if the engine has been bored out ?
My seat o pants meter tells me that something good was done as she really Rip's.
Thanks Jim
  • keith1
  • keith1's Avatar
Re: How to tell if engine has been bored out.
22 Apr 2010 17:12
#362459
to my 1975 Z1B.
Thanks Jim
if it rips , ya hate to tear it open....but thats the only way i know of to measure bore......you can pull cam cover and see if the cam ends have any markings on them and measure a lobe and the base circle and the diff is the lift....see if that is bigger than stock......
  • Old Man Rock
  • Old Man Rock's Avatar
22 Apr 2010 17:23
#362461
Obviously one way is undesirable in that remove the head and measure the piston/cylinder bore diameters.... :blink:
Over 70mm then yup, been bored out...
1015cc = 70mm
1045cc = 71mm
1075cc = 72mm
1105cc = 73mm
1135cc = 74mm
1197cc = 76mm
Pretty much anything bigger would require big block and this would be quite noticeable...
Another less intrusive but non 100% way would be to get her on a Dyno... Pending other mods such as Keith mentioned Cams, carbs, head P&P if your up in the mid to high 90's in HP, more then likely it has had some internal work accomplished...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • otakar
  • otakar's Avatar
22 Apr 2010 17:57
#362470
Put a bore scope inside the spark plug hole and see what the shape of the piston dome is.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • timebomb33
  • timebomb33's Avatar
22 Apr 2010 17:58
#362472
1327 cc = 80mm bore
1393 cc = 82mm bore
1428 cc = 83 mm bore those numbers will really give you some zip.
I THINK MY POWERBAND BROKE
  • otakar
  • otakar's Avatar
22 Apr 2010 18:04
#362475
timebomb33 wrote:
1327 cc = 80mm bore
1393 cc = 82mm bore
He would know if he has those sizes because he would have a big-block on the engine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • jimstan
22 Apr 2010 18:11
#362481
Thanks for your info,
One last quick question: Would the cylinder compression change if it was bored out ?
As well as it runs I will just enjoy it until I have to do a rebuild.
  • larrycavan
  • larrycavan's Avatar
22 Apr 2010 18:15
#362482
All else being unchanged...yes it will go up some but you can't just lean on that number as gospel.
Pull a plug, bring a piston up near tdc, lookin the hole and see if it's got a real dome.
  • timebomb33
22 Apr 2010 18:17
#362484
the only way it change cranking compression would be if they put higher compression pistons in it.
  • larrycavan
22 Apr 2010 18:50
#362492
Increased cylinder volume squeezed into the unchanged combustion chamber size and unaltered cam timing should raise the static a hair...not a lot. You won't be able to tell from the PSI number with any certainty unless it's really up there.
  • Skyman
  • Skyman's Avatar
22 Apr 2010 19:50
#362501
How to tell if your engine is bored?
It yawns. Seems disinterested. Keeps looking at its watch.
:laugh: :silly: :blush:
West Linn, OR
  • PLUMMEN
  • PLUMMEN's Avatar
22 Apr 2010 20:01
#362504
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
