Exhaust studs
- T_Dub
Exhaust studs
22 Apr 2010 05:05
Hey all, just wondering if someone could shed some light on something for me. I want to get some new exhaust studs before my head gets here from Mr C. But they're listed as M6x27. It doesn't give a total length or anything. Can someone give me the real dimensions of these studs? Thanks.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Motor Head
Re: Exhaust studs
22 Apr 2010 05:08
Listed as 6x27mm? 6mm diameter 27mm length. The 6mm should be 1.0mm thread pitch.
- T_Dub
Re: Exhaust studs
22 Apr 2010 05:08
Actually never mind, mods you can delete this. I'm gonna wait and see if I need a different size than stock because of the new header.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Old Man Rock
Re: Exhaust studs
22 Apr 2010 05:31
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- T_Dub
Re: Exhaust studs
22 Apr 2010 05:34
Yeah I can get stock ones easily enough, I was just wondrin what size to tell them when I go to the local fasteners place. They always have what I need, and its cheaper and faster than ordering stock parts online.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- JMKZHI
Re: Exhaust studs
22 Apr 2010 08:14 - 22 Apr 2010 08:15
Without really knowing, I'd check into seeing if 8mm studs can be used - they'd be stouter than the puny stockers - I cringe whenever I tighten them down.
Last edit: 22 Apr 2010 08:15 by JMKZHI.
- T_Dub
Re: Exhaust studs
22 Apr 2010 08:27
Oh it wouldn't be hard to drill and tap for 8mm studs. Looks like there's plenty of space. I was just thinking this myself.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
Re: Exhaust studs
22 Apr 2010 08:57 - 22 Apr 2010 09:28
Haven't seen anything about this in a while, but new exhaust studs used to be listed and described as having "interference fit" threads on the end that screws into the head. And cautioned to be sure they were correctly oriented when installed. Also warned that similar hardware store items didn't have the requisite "interference fit."
Might be hallucinating, but vaguely recall some years ago that Z1E carried the interference fit variety.
Am guessing this was supposed to allow the nut to be removed without turning the stud.
Must have been in the days before Hi-temp Loctite (if there is such a thing).
Meanwhile, it's back to the peanut gallery. :lol:
Good Fortune.
Good Fortune.
Last edit: 22 Apr 2010 09:28 by Patton.
- T_Dub
Re: Exhaust studs
22 Apr 2010 09:05
From my experience exhaust studs usually seize into place quickly anyways haha.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Injected
Re: Exhaust studs
22 Apr 2010 18:26
I have a 650 head with M8 studs... there are no issues in doing that modification.
If you try to get the studs at a local fastener place you might get some blank stares... I ended up getting mine from a local place that works on old air cooled VW engines.
Do KZ1000 motors use M8 studs? never checked...
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
- retterath
Re: Exhaust studs
23 Apr 2010 11:52
I have no experience with this related to Kawasaki and will bow to the knowledge of someone wiser, but I know that VW used small head studs because they will expand/ contract at a rate similar to the head /case material. . .
Bigger isn't always better.
