very very annoying oil issue
- Captaingamez
21 Apr 2010 10:32 #362150
by Captaingamez
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
very very annoying oil issue was created by Captaingamez
Basically the issue is with the crankcase breathing. i took the original breather off and fitted a shorter kz550 breather without the internals. i then routed that to a breater filter. ran fine for about 7 miles on the freeway, then the filter blew oil everywhere
put a catch tank on it, same issue
blocked off the breather and breathed it out of the starter hole. riding distance increases to about 15 miles then blows oil everywhere
put a catch tank on that - same issue
i have a stock internals motor with a light port job on the head, and 4-1 exhaust, and pod filters, re-jetted, ect.
just rebuilt the bike, using different gear ratios on 530 chain.
really wish i could get this fixed, with the newly built frame this thing handles amazing but thats useless if i cant ride it nonstop without issue.
thanks.
thanks.
1971 Yamaha AT1
1971 Skiroule 300rr
- T_Dub
- Thank you received: 25
21 Apr 2010 10:42 #362151
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic very very annoying oil issue
This is either caused by too much crankcase pressure, ie cylinder blow by, or by too much oil in your crankcase.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Captaingamez
21 Apr 2010 10:49 #362152
by Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
Replied by Captaingamez on topic very very annoying oil issue
my compression isn't amazing but its not bad, and the engine runs absolutely perfect on top of that, if this were the case wouldn't it do it when it was cold more than when its hot?
and this happens when the engine is low on oil as well as above level
1971 Yamaha AT1
1971 Skiroule 300rr
- bountyhunter
- Thank you received: 337
21 Apr 2010 10:56 #362153
by bountyhunter
Replied by bountyhunter on topic very very annoying oil issue
If it was just rebuilt, I wonder if there might be a collapsed/broken piston ring letting it blow by there. I don't know where else the pressure could be coming from.
- timebomb33
- Thank you received: 10
21 Apr 2010 11:09 #362159
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic very very annoying oil issue
did you use one piece head gasket or a two piece when the motor got built. if one piece then you may have a problem with the oring groove in the center of the cylinder what did you do top fill that area in if it's not oil or heat resistant then it could have pushed out. if you used a two piece then you may have a problem with the center oring being cut or deformed some way when it was in stalled either one of those situations can cause what your describing. it can allow an improper seal on the two center cylinders and allow combustion pressure to blow past and down the cam chain tunnel pushing the oil out, also recheck the cylinder head tourque the best way to figure out where the problem is occuring is with a leak down test.
- Captaingamez
21 Apr 2010 11:35 #362161
by Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
so are you telling me that this has nothing to do with the breather modifications i have done?
i used a 2 piece i ordered from z1 with the o ring for the tunnel.
i haven't re-torqued the head yet but will do immediately.
and, wouldnt any of these problems cause the engine to run improperly? and wouldnt the crankcase smelling at least faintly of gas, or burnt gas?
1971 Yamaha AT1
1971 Skiroule 300rr
- timebomb33
21 Apr 2010 17:20 - 21 Apr 2010 17:23 #362213
by timebomb33
if you have a problem with a gasket sometimes you will hear a sound that sounds alot like birds chirpping. i have done that same mod to a few different engines to gain room for bigger carbs and i haven't had any thing bad happen because of it, myself that is it a fairly routine job that has been done on hundreds of bikes.
Last edit: 21 Apr 2010 17:23 by timebomb33.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
21 Apr 2010 17:30 #362215
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic very very annoying oil issue
Drop your oil level some, and recheck.
I have seen newly built engines blow by alot in the first 30 or so miles.
GET IT HOT, RIDE IT HARD.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
