- Thank you received: 1
Rebuild first time fireup....a problem!?
- polkat
Pulled them tonight and they are all like this, although this one is the worse. As you can see, they have been on there so long that the rubber is impressed with the shape of the head port. This whole surface was also wet with gas, and there are also little radiating cracks in the rubber away from the hole.
I suspect that this is my problem. Now, as some of you know...I'm very poor and do things with a non-budget. I can't afford to replace these right now, so I'm wondering if I can smear some kind of sealer in there as a temporary fix?? Thanks!
- bountyhunter
- Thank you received: 337
- bountyhunter
No gaskets used there.
By the way, the engine had no gaskets between these rubbers and the head. I guessed that was because the rubbers are fully coated with rubber, and I assembled it that way. Right....?
- Thank you received: 2098
- JakeB
I just got new ones, but my old ones are in a lot better shape than yours. They are the VM26/28 style with the vacuum ports for the KZ1000. Not sure if they will work for you or not, but if so they are yours for the cost of shipping.
1978 Z1-R
- polkat
I have a product here by Permatex called Moto 1 sealer, which is a rubber instead of silicon. Supposed to be good around gas. Think I'll try it....no?
Thanks JakeB, but I have the Keihin CV34's, and I think yours are a different size.
Depends on the temp range intended for the product.
The Ultra Copper Hi-Temp is for up to 750 degrees and recommended by Permatex for manifolds.
The spray rubber is good stuff, but for up to 350 degrees, and recommended for other things besides manifolds.
Don't know temp range of Moto 1.
I would use the Hi-Temp stuff and be done with it.
- polkat
- polkat
