cylinder head
- limp
20 Apr 2010 09:23 #361897
by limp
Hi
I'm Graham (limp)I live in the Leicestershire area of England have just finished this Z1000,it is an H1 engine fitted with carbs which are 29mm mikuni's,LTD frame,Yamaha FJ1100 front end it handles very well and goes like a rocket
cylinder head was created by limp
Hi all i just want to know if a KZ1000 cylinder head will be ok to use with KZ1100 barrells
Hi
- otakar
20 Apr 2010 09:49 #361903
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic cylinder head
If it is a "J" model 1000 than yes if it is a MKII head or earlier than no. If you are trying to use 1100 jugs on a MKII or earlier block than it will not work also.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- limp
21 Apr 2010 16:34 #362206
by limp
Hi
Replied by limp on topic cylinder head
Thanks for that otacar
Hi
