Milling cylinder block
- rayellis
19 Apr 2010 14:40 #361741
by rayellis
Milling cylinder block was created by rayellis
Can anyone tell me how much can be milled off the cylinder for a 1980 KZ750 4 cylinder? Can I increase the base gasket size to off set this difference?
Thank You
Ray
Thank You
Ray
- mark1122
- Keep twisting it
- Thank you received: 109
19 Apr 2010 14:49 #361743
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Milling cylinder block
i cant give u a # , but i can give u some info.
u need to measure the distance between the head and the pistons outer edge. the min gap on a kz900 and up is .040" for a street motor. this includes the base and head gasked after compresion.
why would u want to remove it from the top and add it back with a base gasket?
i have actualy done this in my current 1200cc motor.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- T_Dub
- Thank you received: 25
19 Apr 2010 14:57 #361745
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Milling cylinder block
Only reason I can think of is a warped firedeck?
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- rayellis
19 Apr 2010 19:17 #361797
by rayellis
Replied by rayellis on topic Milling cylinder block
Yeah something like that but not warped. Some reason the piston sleeve is lower on one piston and the machinist said it would need about 30 thousands taken off. The deck around this piston sleeve is slightly higher just enough to get a fingernail on it. I don't think it needs that much but the machinist thinks it does.
Funny thing about that cylinder is the sleeve on that one has these grooves in it but the other three are smooth. This is looking down at the top of the cylinder the walls on top of the sleeve have circular grooves on the top of the sleeve.
- rayellis
19 Apr 2010 19:22 #361800
by rayellis
Try to send pics but this will be hard to see.
- Tony
- Thank you received: 13
19 Apr 2010 21:27 - 19 Apr 2010 21:31 #361820
by Tony
Replied by Tony on topic Milling cylinder block
I just did this on my bike engine. My sleeves were sunk down .028" At first I thought it wasn't much. I could feel it with a finger nail. But when I actually measured it, it was .028" The machinist took off .030" to true it up. I recently had my head decked too and at that time he took off .006"
I ordered a .040" aluminum cylinder block spacer from ape to compensate for this. This is how I chose to fix the problem.
From APE:
KAWASAKI Z1900/KZ1000 / GPZ1100 thru '84
THICK PART# PRICE
.020" CYSPK020 $58.00
.040" CYSPK040 58.00
.063" CYSPK063 58.00
.080" CYSPK080 65.00
.125" CYSPK125 73.00
From APE:
THICK PART# PRICE
Last edit: 19 Apr 2010 21:31 by Tony.
- mark1122
- Keep twisting it
20 Apr 2010 05:05 - 20 Apr 2010 05:11 #361852
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
if the cyl is sunk, it will not seal properly.
u can take some material off, and replace it at the bottom with a shim.i dont use the base gasket in this circumstance.therefore i would add .020"(or what ever thickness the base gasket is , after compression) to the shim thickness to make up for the loss of base gasket.u dont need to come back up as high as the original block was , just as long as u have a min of .045" from head to block with all gaskets in, and after all gaskets are compressed.use Gaskasinch, or Copper kote on both sides of the shim.
before u start.
measure the current clearance.
put the old gaskets back in and re-torque the head(no cams).now put 2 pieces of solder in through #1,or 4 spark plug hole. hold the solder in place, over each wrist pin, AT the outer edge of the piston. now turn the crank over to compress the solder.now just measure the solder.Now u have a max clearance #. let us know what this # is.
before u start.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 20 Apr 2010 05:11 by mark1122.
- Thank you received: 797
20 Apr 2010 09:35 #361900
by 531blackbanshee
Replied by 531blackbanshee on topic Milling cylinder block
to help clarify what mark is talking about.he is telling you to check the squish,which is the distance between the piston and the combustion chamber.
i am a translator from canadian to american :laugh: :silly: .
- APE Jay
- Banned
- Thank you received: 58
21 Apr 2010 16:17 #362197
by APE Jay
Replied by APE Jay on topic Milling cylinder block
The sleeve that is low was apparently changed in that block. The groove is because it was cut for an o'ring.
I would suggest replacing that sleeve with another smooth one. Be sure you press all of the sleeves down in a press before you surface it. If they are not seated, they will drop when the motor warms up and you will be right back where you are now.
