Potential 650 c engine swap?
- Jodyb17
17 Apr 2010 08:24 #361311
by Jodyb17
1977 KZ 650 C
Potential 650 c engine swap? was created by Jodyb17
I have a 77 650c that has been sitting a while (years). To get it running I think a rebuild is in my future. I was wondering if swapping the engine would potentially be a cheaper and easier solution.
Assuming my theory is correct, what years/models 750's will fit into my frame without modification? I did a quick search in this forum, but didn't find the info.
1977 KZ 650 C
- Jodyb17
23 Apr 2010 14:42 #362665
by Jodyb17
1977 KZ 650 C
Replied by Jodyb17 on topic Potential 650 c engine swap?
Nobody? Is my question a silly one? I assumed I could swap a 650 for a 750. I realize I may be trading one set of problems for another.
Should I just dive in and see how bad the situation is? I am a bit leery about doing engine work. I am somewhat mechanically inclined, but by no means a gearhead.
If the engine is just seized at the piston rings do I need to pull the pistons or can they stay in place after I pull the cylinder block?
What is a decent price for new cylinder rings?
Thanks guys.
Thanks guys.
1977 KZ 650 C
- bigkaw815
- Thank you received: 1
23 Apr 2010 15:11 #362669
by bigkaw815
Replied by bigkaw815 on topic Potential 650 c engine swap?
Why not dig in and learn a few things while amazing yourself at your resolve and powers?
- Jodyb17
23 Apr 2010 16:10 #362689
by Jodyb17
1977 KZ 650 C
Good point. I guess I need to grow some cajones.
Does it make any sense to stick with 650 cylinders?
I can put a 750's cylinder block and head onto my bottom end can't I? If that's correct, what model years mate up with my 77?
What is involved in making that switch?
1977 KZ 650 C
- Thank you received: 2098
23 Apr 2010 16:37 - 23 Apr 2010 16:41 #362699
by Patton
Replied by Patton on topic Potential 650 c engine swap?
Click >
Includes excerpt below
I am pretty sure that reborn650 did this with his. I think he got 750 barrels bored to 810 and I know he used his original 650 head as I saw it one summer evening in his garage and remember he had the 650 cam chain rather than the hyvo chain used on the 750.
That was quite the bike - a 650 with 810 displacement. I cant remember what he did for carbs. He may have used the Mikunis from the 650 and jetted up. I can remember velocity stacks. He has'nt been here in a while. HOpe he ws'nt arrested. That thing was a screamer
Try a search. There was a big thread on this about 2 years back.
Do forum search on "reborn650" to find links to some good threads related to this subject.
Last edit: 23 Apr 2010 16:41 by Patton.
