1977 kz650 will not start
- runningtat
16 Apr 2010 19:22 - 16 Apr 2010 20:45 #361222
by runningtat
1977 kz650 will not start was created by runningtat
hi all, slight problem here....no spark in spark plugs 1 and 4..no spark in left point...3 and 4 have good spark at the plugs and points
any suggestions.....condenser issue..ignition coil what values should i be looking at with a voltmeter for the condenser and ignition coil..no manual yet!!!!
runningtat
1977 kz 650
nova scotia , canada
runningtat
1977 kz 650
Last edit: 16 Apr 2010 20:45 by runningtat.
- BSKZ650
- Thank you received: 14
17 Apr 2010 10:37 #361337
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic 1977 kz650 will not start
verify that you have voltage to the coils first, next look at the plug wires, and reset the gap on the points making sure they are clean, prefer new points and condensors
- bill_wilcox100
- Thank you received: 5
17 Apr 2010 12:31 #361350
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic 1977 kz650 will not start
Assuming that you have followed the advice above and checked that the voltage across the Coil(s) input is no less than say 0.5 Vdc of the voltage directly across the battery then try the following:
Swap the two coils. If the symptom follows the coil then be prepared to replace the coil... preferably with a new coil (don't ask).
If the symptom does not follow a coil then it may be a trigger (Points, Condenser) fault. Swap the Points.
If the problem follows the Points be prepared to replace with new Points.
If the symptom does not follow the Points then swap the Condensers... you get the idea from here.
Best of success,
Bill
Best of success,
Bill
Upgrades:
Montreal, Canada
- runningtat
18 Apr 2010 08:20 #361456
by runningtat
Replied by runningtat on topic 1977 kz650 will not start
thanks for the response. any input on how to set the points ..that is new to me...thanks
runningtat
1977 kz650
nova scotia, canada
runningtat
1977 kz650
nova scotia, canada
