How well built are the EK 219H camchains?
- oppie501
- keith1
- Thank you received: 2
- Thank you received: 2829
- keith1
30K isn't much on a cam chain if oil has been maintained. Before replacing you may want to measure as described in factory service manual. You may find it is well within spec. My KZ650C1 has nearly 50k miles and the chain is nowhere near the service limit yet. Ed
good point..!..
- oppie501
- keith1
Yes I believe it is. I think z1 offers 2 different camchains. The tsubaki and the ek. Just curious, what happened, to run yours through the ringer?
i reset my cams without removing ape tensioner...just backed it out all the way.....no slight on the ape tensioner, still use it....anyhow,after i had it running again , chain was noisy....tightened some more.....noticed bits in oil on a 1000 mile rebuild.....took it apart....chain had jumped oem rear sprocket and was riding
between sprocket and the bracket holding sprocket to tensioner......rookie mistake......i learned 2 things....always fully remove tensioner when re-setting cams and be aware that a too tight cam chain is not a good thing......very expensive lesson.....
