Engine swap - advice needed
- Aumriff
15 Apr 2010 11:50 #360850
by Aumriff
KZ650 F2 (1981 UK/Euro model)
K+N Pods, Marshall 4-1 exhaust
Living in the UK
Engine swap - advice needed was created by Aumriff
Hi all, I have the chance to buy a near perfect condition kz650B1 engine for £180. Can I drop this straight into my kz650F1 frame?
Living in the UK
- OnkelB
- Thank you received: 80
15 Apr 2010 12:57 - 15 Apr 2010 22:05 #360870
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Engine swap - advice needed
Physically I'm pretty sure it'll be a straight swap, but you will face some electrical issues.
While the F1 has a permanent magnet 1-phase alternator with a combined regulator/rectifier the B1 (77) runs a 3-phase excited field alternator with a separate (electromechanical) regulator and rectifier - this setup is unique to the 77 models (B1 and C1) and later model reg/rec's will not work with the 77 alternator. This is not just a question of 1-phase vs. 3-phase, the 77 runs a field coil and later model reg/recs do not have an output to feed the field coil, completely different animals.
This leaves you with two options, provided you still have the F1 engine:
1: Install the 77 engine, get hold of a 77 regulator and a 77 rectifier and modify your harness.
2: Swap your F1 rotor/flywheel, stator and stator cover onto the 77 engine and use the F1 reg/rec, no mods to the harness required. This may take some slight modification (drilling) of the F1 stator cover as the 77 models may have the cover dowel pins located differently from later models.
Personally I would prefer the latter or better yet (third option), stick a 750 or GPz 750 engine in it if you can find one.
Last edit: 15 Apr 2010 22:05 by OnkelB.
- Mark Wing
- Thank you received: 22
15 Apr 2010 23:04 - 15 Apr 2010 23:05 #361026
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Engine swap - advice needed
Yeah it will go in no problem. I would switch the rotor and cover and not even mess with the wiring. Or like OnkelB said a KZ/GPZ 750
Mark
Mark
Yorba Linda Cal.
Last edit: 15 Apr 2010 23:05 by Mark Wing.
- H1Vindicator
- Thank you received: 51
16 Apr 2010 04:38 - 20 Feb 2013 20:08 #361035
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 20 Feb 2013 20:08 by H1Vindicator.
