Engine noise
- gotakz
15 Apr 2010 08:15 #360822
by gotakz
1976 Kz900-A4
Had a 1985 Gpz750
Engine noise was created by gotakz
I have a 76 kz900 that has started to make a rattling noise that does not happen at idle. Crack the throttle and rattle ,rattle. I took the valve cover off and found that the cam chain is really loose at the top guide sprocket. Should it be tight? If so can it be tightened or do I need to replace the chain. Thanks
1976 Kz900-A4
Had a 1985 Gpz750
- Thank you received: 2829
15 Apr 2010 10:25 #360838
by 650ed
Replied by 650ed on topic Engine noise
Have you performed the cam chain adjustment as described in the Kawasaki factory service manual?
- gotakz
16 Apr 2010 08:15 #361110
by gotakz
1976 Kz900-A4
Had a 1985 Gpz750
Replied by gotakz on topic Engine noise
I checked the adjustmets and the chain tensioner must have been stuck because now it's fine. thanks
1976 Kz900-A4
Had a 1985 Gpz750
