6SPEED IN A KZ750
- 750with6
ITS BEEN 3 WEEKS WITH THIS 6SPEED IN THE BIKE AND ITS WELL WORTH THE EFFORT AND I HAVE HAD ZERO PROBLEMS SO FAR I DID HAVE A GUY EMAIL ME AND SAID HE DID THIS IN THE 80'S AND SAID THEY HAD TROUBLE WITH 2 GEAR SHIFT FORK BENDING AT DECELERATION WITH A LOAD SO WE WILL SEE WHAT HAPPENS,AS FOR INSTALLING THE GPZ550 6SPEED IN THE KZ 750 ITS A DIRECT DROP IN.I USED THE COMPLETE TRANS OUT OF THE 550 SHIFTING FORKS DRUM EVERYTHING,THE ONLY THING I RAN INTO WAS THE SPLINES ON THE 550 SHAFT ARE SHORTER THEN THE 750 SHAFT SO THE CLUTCH HUB IS TO WIDE SO WHEN YOU TIGHTEN IT DOWN THE THEADS NEVER GET TO THE LOCKING PART OF THE NUT WHAT I DID IS GROUND DOWN THE NUT SO THE THREADS WOULD REACH THE LOCKING PART,BUT IF YOU USE THE CLUTCH HUB OUT OF THE 550 IT SHOULD BOLT UP JUST FINE.AS FOR THE OUTPUT SHAFT I WELDED THREADS ON MINE SO I COULD USE THE LOCK WASHER AND NUT TO HOLD THE SPROCKET ON.IM DUNNING A 14TOOTH IN FRONT AND 33 IN THE REAR AND MY RANGE PER TANK OF GAS HAS IMPROVED BY 50 MILES IM GOING TO TAKE A ROAD TRIP TO SEE WHAT KIND OF MILEAGE I GET I WILL KEEP YOU UPDATED .
- JR
- Thank you received: 448
Thanks
Great looking bike
- DrWhizBang
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
- JMKZHI
- Thank you received: 48
- bountyhunter
- Thank you received: 337
- thompsonmx100
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
- cafekz750
The 550 transmission in a 750 offers more of a close ratio gear box than an extra or overdrive gear with no modification of the front and rear sprockets. At least according to the Kawi specs. If you were to modify (reduce) your sprocket ratio to gain top speed, then it would be more of an overdrive.Thanks for the info. It would be nice to have an extra gear.
Borrowed from this link:
6 speed in GPz 750 questions
koolaid_kid wrote:
Thanks, apeman. I checked the archives, someone named Mark Bell was not successful in putting a 6 speed into a 650, apparently due to the kickstarter issue.
I did check the gear ratios, they are as follows:
550
1st 2.57
2nd 1.78
3rd 1.38
4th 1.13
5th 0.96
6th 0.85
750
1st 2.33
2nd 1.63
3rd 1.27
4th 1.04
5th 0.88
It has a lower first gear, kind of mixed in the middle gears, and a slightly higher 6th gear. The overall spread is wider, but geared to the lesser power of a 550.
Since the bike will primarily a canyon carver, this is ideal for me. When chain replacement time comes, I will probably play with the sprocket ratios a bit to make it more ideal for the added power of a 750.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
- hardr0ck68
- Who put the what in the where?
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- 750with6
- AtLarge
- Thank you received: 21
I wish my 750 twin had a sixth gear. Some days I try to shift up to the next gear when I am in fifth gear on the expressway.:laugh:
Same here. Wish this was doable for our model.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
