Engine Swap
  • wrangler615
  • wrangler615's Avatar Topic Author
Engine Swap
12 Apr 2010 19:05
#360218
Heys guys, need some knowledge. I am looking into replacing the engine in my bike (750-4, shaft drive), and wondered if any body knows what will interchange. My main concern would be getting a chain drive engine. Do any of you know if I can bolt the shaftie's primary drive to the chain drive engine? It is a completely seperate unit on my bike, save for having oiling passages. Anyone know what would be needed for this swap? Are the cases different? Any input is appreciated.
Thanks in advance.
83 Kaw KZ750F1 - massive money pit
82 Zuki GS1100G - my daily driver, possible sacrilege I know
  • wrangler615
Re: Engine Swap
13 Apr 2010 19:28
#360493
Anybody?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Engine Swap
13 Apr 2010 20:06
#360502
how about a shaft drive 1000/1100 motor?
  • wrangler615
Re: Engine Swap
14 Apr 2010 09:08
#360607
I like your thinking Plummen! How would that be for a shaft drive power cruiser?!:woohoo: So that begs another question. I'm sure I could fit it in the frame with a little persuation, but would the shaft line up?
  • porchev914
  • porchev914's Avatar
Re: Engine Swap
14 Apr 2010 09:44
#360610
If it doesn't line up, it only means you need to use a bigger hammer :laugh:
All joking aside, you may need to adapt the shaft swingarm from the engine donor bike as well. If it doesn't bolt right up, I can't imagine it would be that much fab work to squeeze it in B)
FRANKEN Z!
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Engine Swap
14 Apr 2010 09:45
#360611
I would suspect that you should also acquire the shaft drive and the swing arm if you are upgrading engine sizes...but I have no direct experience with doing this.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • School Teacher
  • School Teacher's Avatar
Re: Engine Swap
14 Apr 2010 12:23
#360642
i have a 1000 shaft drive swing arm and rear wheel you can have if you go that route, and any misc parts i have, i just dont have an engine for it. At least not a complete one. any way i dont know where you are im in oregon. good luck
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
