no spark, gas overflowing through drains
- runningtat
12 Apr 2010 06:54 #360087
by runningtat
no spark, gas overflowing through drains was created by runningtat
hi all new to the site...1977 kz650 will not start for the season...took the carbs apart cleaned them,cleaned the gap at the point and spent 3 hours trying to get the carbs back on the bike...anyway... bike still will not start...no spark, gas overflowing through the drains.....need serious help....
- BSKZ650
- Thank you received: 14
12 Apr 2010 08:05 #360093
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic no spark, gas overflowing through drains
Welcome, first off, the needles and seats are not sealing, could be that you need new ones or a complete kit, it also can be that the floats are set too high, either way the carbs will prob need to come back off.
Make sure you have NEW plugs and NEW fuel filter in line, you may have a lot of trash in the tank that is getting back into the carbs.
- Thank you received: 2829
12 Apr 2010 14:48 #360165
by 650ed
Replied by 650ed on topic no spark, gas overflowing through drains
If all carbs are overflowing are you sure you didn't put the floats in upside down? Ed
- Motor Head
- Thank you received: 391
12 Apr 2010 18:02 #360196
by Motor Head
Replied by Motor Head on topic no spark, gas overflowing through drains
No spark? Got 12 volts on the Positive coil terminal? You said you "Cleaned" the point gap, is it set correctly? Did you remove the wires off of the terminal and miss install it so it is grounded all of the time? Pull the negative wire off at the coil and check to see that the wire makes and breaks contact to ground as the motor turns by hand.
Listen to the other guys and clean your tank, put in an in line filter and get some carb kits with new needle and seats get the float level correct. Make sure to get the Idle and transfer circuit really clean as this is most of the poor running issues. Get or make a carb sync tool, sync em good.
