- Thank you received: 3
Not firing and backfiring 1, 3 cylinders
- jimstan
10 Apr 2010 16:16 #359734
by jimstan
Not firing and backfiring 1, 3 cylinders was created by jimstan
I have a 1975 Z1B that is not firing and backfiring both 1, 3 cylinders ?
Spark is strong on all 4 cylinders.
The bike has new Dyna ingnition and coils.
WireGeorges wire mod.
Carbs are 29mm smoothbore.
Solid State regulator fron a later year KZ.
I was not able to check output of regulator as I was unable
To get above idle.
Bike was running fine before I put in regulator, wire mod and cleaned carbs.
Firing order is set and checked at 1,2,4,3
No changes to valve train.
I would have jump on the carbs if it just was not firing on 1,3 but backing at 1,3 ??? any helpor suggestions ????
Jim
To get above idle.
Jim
- Jeff.Saunders
10 Apr 2010 16:36 #359737
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Not firing and backfiring 1, 3 cylinders
Check the plug wires again.
It sounds like you have 1&2 cylinders coming from one coil and 3&4 from the other.
It should be 1&4 from the same coil, and 2&3 from the other.
Z1 Ent on Facebook,
- TeK9iNe
- What did you do!?!
- Thank you received: 28
10 Apr 2010 19:19 #359827
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Not firing and backfiring 1, 3 cylinders
Jeff.Saunders wrote:
YEP! Wires incorrect/reversed...
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
10 Apr 2010 22:14 #359856
by Patton
Replied by Patton on topic Not firing and backfiring 1, 3 cylinders
- jimstan
12 Apr 2010 13:27 #360154
by jimstan
Replied by jimstan on topic Not firing and backfiring 1, 3 cylinders
Thanks for the suggestions, I rung out the wiring and everything is in its place.
I will pull the carbs and go over them again as a place to start.
12 Apr 2010 15:08 #360168
by Patton
When replacing points with Dyna-S, the points cam is also replaced with a Dyna-S rotor.
The Dyna-S rotor has a small magnet embedded that triggers each pick-up module as it passes by the module.
If the Dyna-S rotor is installed 180 degrees off, it has the same effect as if the signal wires from the Dyna-S modules are reversed and connected to the wrong ignition coils.
I would align the F mark for 1/4 with the permanent case timing mark and assure that the rotor magnet is then on the rotor's west side next to the left-hand Dyna-S module. If the magnet is then on the opposite side toward the right-hand Dyna-S module, the rotor is 180 degrees off.
- jimstan
13 Apr 2010 10:19 #360354
by jimstan
Patton wrote:
Patton you were dead on, took a second look at the coils I missed it the first time but my coil wires were reversed.
Thanks again. Bike is running great.
JIM
[Click on image to enhance view.]
[MIG size=800] kzrider.com/media/kunena/attachments/leg...0fe3fb643c25c423.JPG [/img]
JIM
