Cam shafts
- 7879KZ650S
- Injected
- Thank you received: 543
Andrews offered the following grinds for the 650/750 Kawasaki :
#10- 236D .330"L - Bolt in Stock cups & springs 2500RPM+
- 7879KZ650S
- 7879KZ650S
- 7879KZ650S
- Nebr_Rex
- Thank you received: 300
I had been kind of scared to put these cams in myself, but in my spare time I have looked the bike and the cams over. Looks like there may not be much to it. Does anyone know the torque specs on the cam journals?
11 ft. lbs.
time the cams to factory specs.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- 7879KZ650S
- porchev914
- Thank you received: 19
FRANKEN Z!
- larrycavan
- Visitor
Thanks, is there a spec on the cam to sprocket bolts?
Use red loctite on the threads. Make sure you clean the bolts and the cam bolt holes with brake clean and blow them out.
Pick up a bottle of LL5 lifter lube at your local NAPA store and lube the cams and buckets well with it. I always follow break in procedures even with used cams.
- BSKZ650
- Thank you received: 14
11 ft. lbs.
dont have my book here, but seems to me it was in inch lbs not ft?
77 ltd1000, current rider
76 kz900, just waiting
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- chrispysaki
The torque for the cam shaft caps is 104 in./lbs. (or roughly 9 ft./lbs)
