oil lite comming on
- fochtup1
07 Apr 2010 18:37 #359103
by fochtup1
oil lite comming on was created by fochtup1
hello, i have an 81 kz 1100 shaft and the other day the oil lite started to come on at about 3000rpms very dim and will go off below and above 4k. does not do it all the time and never at idle. change the oil and filter tonight and still happened when i took it out. last night it started after i hit a rough spot on the road, that was a three mile trip. this morning rode to work about 10-15 miles was at work for about an hour then rode back home 10-15 miles and it did not come on. i am guessing a bad sending unit but whats your opinions.
thanks, justin
thanks, justin
- Thank you received: 2829
07 Apr 2010 18:42 #359108
by 650ed
Replied by 650ed on topic oil lite comming on
Might want to check the connection where the wire attaches to sending unit. Ed
- fochtup1
07 Apr 2010 19:07 #359117
by fochtup1
Replied by fochtup1 on topic oil lite comming on
i'll check that went to check yesterday and my ADD kicked in and forgot that i just parked it 5min early and burned the crap out of my fingers:ohmy:
- Old Man Rock
- Thank you received: 225
07 Apr 2010 19:15 #359123
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic oil lite comming on
If your oil sending unit is designed and operates similar to the KZ900/1000 units...
This is a pressure switch where if pressure is low, it will stay grounded to the frame henceforth, oil lamp on....
Example, first turn on the ignition switch, pressure is null, lamp turns on... Once started, pressure forces the spring/contact up to disengage engine ground thus oil lamp turns off.
Again, this is for the KZ900/1000 models and yours may be different... Best wise to confirm in your service manual for operations.
Just a thought....
OMR
Just a thought....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
