- Thank you received: 6
Head is back on!
- fordtruck
06 Apr 2010 22:24 #358902
by fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
Head is back on! was created by fordtruck
This morning I installed my freshly rebuilt and ported head. I got as far as getting the cams back in and the top cam chain idler sprocket back on.
My goal tomorrow is to install the cam chain tensioner and verify cam timing. I should also have time to get the intake manifolds on and maybe the carbs. With a little luck I'll hear it roar to life by the weekend.
It's been nearly three months since I tore my motor apart in preparation for the 1075 build. I'm seeing the light at the end of the tunnel now!
- mark1122
- Keep twisting it
- Thank you received: 109
07 Apr 2010 02:57 #358915
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Head is back on!
Good luck.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- larrycavan
- Visitor
07 Apr 2010 04:33 #358922
by larrycavan
Replied by larrycavan on topic Head is back on!
Put sealer on the intake boots Use allen bolts, they're easier to tighten up with the head on the motor and the motor in the frame.
Dip your shims in some oil when you get the final setting for your valves. The oil helps hold the shim in the bucket.
I'd go max loose on both sides with the lash adjustment.
Also, remember to get after the head nuts with the torque wrench after the first heat cycle and cool down. DON'T SKIP THAT STEP
- keith1
- Thank you received: 2
07 Apr 2010 07:25 #358951
by keith1
Replied by keith1 on topic Head is back on!
we want pics and/or vid!!!!!!!!!!!
- elseed
07 Apr 2010 08:27 #358963
by elseed
'75 Z1B with mods
Replied by elseed on topic Head is back on!
After setting timing, if you feel any resistance while gently turning the engine, for God's sake STOP and don't force it!
Bending a couple of gleaming fresh valves cause you're in a hurry is supposedly a major bummer, expensive, and emotionally draining. Or so I've heard.
'75 Z1B with mods
