want to make KZ1000 faster
  • KZ1000CSRman
  • Topic Author
06 Apr 2010 14:59 #358795 by KZ1000CSRman
want to make KZ1000 faster was created by KZ1000CSRman
How can I make my 1982 CSR1000 any faster than stock? Are there any tricks or cheap modifications I can do to it?
'82 KZ1000 CSR
06 Apr 2010 15:06 #358796 by kawsakiman
Replied by kawsakiman on topic want to make KZ1000 faster
speed costs money.
how fast do you want to go?
cheapest little hop up is pods, rejetting and a header.
it just snowballs from there.
06 Apr 2010 15:15 #358798 by otakar
Replied by otakar on topic want to make KZ1000 faster
kawsakiman wrote:
speed costs money.
I agree with all.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • 9am53
  • homebrew, and some bbq
06 Apr 2010 16:28 #358818 by 9am53
Replied by 9am53 on topic want to make KZ1000 faster
Cheaper than that is upgrading your cams...may not sound cheaper but you have the weakest cams in the KZ1000 lineup, you can get some J cams for free (I did) or 2 different kinds of GPz cams that will drop into your bike. The GPz ones may be a little money, but for the cost of some throwaway cams and a gasket you can go faster.
06 Apr 2010 16:54 - 06 Apr 2010 16:55 #358832 by 650ed
Replied by 650ed on topic want to make KZ1000 faster
Here's a little inspiration from 1979:
Last edit: 06 Apr 2010 16:55 by 650ed.
  • TeK9iNe
  • What did you do!?!
06 Apr 2010 17:10 #358842 by TeK9iNe
Replied by TeK9iNe on topic want to make KZ1000 faster
When trying to decide on the components you want to use for a rebuild project, take some time to consider how the components interact and effectively contour the behavior of the engine.
Remember the 3 ways to improve performance are:
Make it bigger
Spin it faster
Make it more efficient
The actual practice is to consider all 3 methods and from them determine if you will get the result you desire from just performing 1 of the 3 methods.
In the case of the big block, performing method 1, yields nice gains down low and in the middle but leaves the motor starving for enough air to fill the cylinders at the upper regions of the power band.
This also plays into the budget scenario. It costs far less to put together a 1075 with a good cylinderhead than it does to build a big block motor. On the other hand if you have the budget for everything, the big block can then deliver an exceptional performer all around.
ALL STRAIGHT FROM LARRY... not mine ;)
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
06 Apr 2010 17:13 #358844 by PLUMMEN
Replied by PLUMMEN on topic want to make KZ1000 faster
start with a good tuneup,you might be shocked! :laugh:
06 Apr 2010 17:50 #358847 by Old Man Rock
Replied by Old Man Rock on topic want to make KZ1000 faster
SInce you said cheap... Assumption faster meaning faster off the line then cgange your gear ratio of your sprockets.
Example... go up 2 teeth count on the rear sprocket since it's the cheapest of all other options... Pending where your chain length falls, you may be ok where no need to obtain longer chain but then again....
NOTE: As somewhat mentioned, everything has pro's and cons... Change your ratios for faster off the line, loose some top end speed in gear ratio changes...
Not cheap... Larger pistons, Performance cams, upgraded carbs such as Keihin CR Specials, and head valve with P&P.... Then throw on a performance 4-1 exhaust, pods and re-jet...
I forget anything.... most likely...
Oh crap, almost did... The coil mod... :whistle:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • larrycavan
  • Visitor
06 Apr 2010 18:36 #358859 by larrycavan
Replied by larrycavan on topic want to make KZ1000 faster
Give that man a cigar :) That's where you start.
06 Apr 2010 20:08 - 06 Apr 2010 20:08 #358879 by 2006hhr
Replied by 2006hhr on topic want to make KZ1000 faster
TURBO!:woohoo: Or tune up, better intake and exhaust flow, etc. But a turbo would be rightous B) but enough smilys good luck with it all
Last edit: 06 Apr 2010 20:08 by 2006hhr.
06 Apr 2010 22:16 #358901 by nads.com
Replied by nads.com on topic want to make KZ1000 faster
Start by pulling lobe centers down that will give u most bang for the buck. What the heck is a tune up?
06 Apr 2010 22:49 #358905 by davel
Replied by davel on topic want to make KZ1000 faster
Yeah. This is good advice for sure. What are you trying to achieve?
