want to make KZ1000 faster
- KZ1000CSRman
'82 KZ1000 CSR
- kawsakiman
- Thank you received: 6
how fast do you want to go?
cheapest little hop up is pods, rejetting and a header.
it just snowballs from there.
- otakar
speed costs money.
I agree with all.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Thank you received: 2829
- TeK9iNe
- What did you do!?!
Remember the 3 ways to improve performance are:
Make it bigger
Spin it faster
Make it more efficient
The actual practice is to consider all 3 methods and from them determine if you will get the result you desire from just performing 1 of the 3 methods.
In the case of the big block, performing method 1, yields nice gains down low and in the middle but leaves the motor starving for enough air to fill the cylinders at the upper regions of the power band.
This also plays into the budget scenario. It costs far less to put together a 1075 with a good cylinderhead than it does to build a big block motor. On the other hand if you have the budget for everything, the big block can then deliver an exceptional performer all around.
ALL STRAIGHT FROM LARRY... not mine
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
- Thank you received: 104
- Old Man Rock
- Thank you received: 225
Example... go up 2 teeth count on the rear sprocket since it's the cheapest of all other options... Pending where your chain length falls, you may be ok where no need to obtain longer chain but then again....
NOTE: As somewhat mentioned, everything has pro's and cons... Change your ratios for faster off the line, loose some top end speed in gear ratio changes...
Not cheap... Larger pistons, Performance cams, upgraded carbs such as Keihin CR Specials, and head valve with P&P.... Then throw on a performance 4-1 exhaust, pods and re-jet...
I forget anything.... most likely...
Oh crap, almost did... The coil mod... :whistle:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- larrycavan
- Visitor
start with a good tuneup,you might be shocked! :laugh:
Give that man a cigar That's where you start.
- 2006hhr
- nads.com
- Thank you received: 20
- davel
Yeah. This is good advice for sure. What are you trying to achieve?
