kz550 oil sending unit
- baldguy
05 Apr 2010 11:42 #358560
by baldguy
kz550 oil sending unit was created by baldguy
I have a dumb question the oil and fuel light is coming on at high revs. I cant for the life of me find the oil sending unit its a 1984 kz550 shaft drive.Thanks
- TeK9iNe
- What did you do!?!
- Thank you received: 28
05 Apr 2010 17:17 #358595
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic kz550 oil sending unit
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- gane
- Thank you received: 1
05 Apr 2010 17:18 #358596
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic kz550 oil sending unit
Not familiar w/ your' bike, but would look under the ign, pick-up cover. (r/h side of crankshaft). G. PS, oil light at revs, is usually due to low oil level, and copious amounts of still thick oil accumulating in top end. before going wild, double check oil level, check after sitting for a couple minutes bike level, you can run level to the top of window safely. luck G
- TeK9iNe
05 Apr 2010 17:18 - 05 Apr 2010 17:20 #358597
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 05 Apr 2010 17:20 by TeK9iNe.
- baldguy
05 Apr 2010 19:06 #358626
by baldguy
Replied by baldguy on topic kz550 oil sending unit
Thanks all I will change oil again that sending unit is $115 wow.
