- Thank you received: 8
Dragbike remote starter?
- gvsu141
05 Apr 2010 06:08 #358505
by gvsu141
2001 ZRX 1200
1973 z1 900
1975/73 z1 Turbo Dragbike
1982 GPZ550 - 62 Miles
Dragbike remote starter? was created by gvsu141
Does anyone have a starter nut for a remote starter laying around or know where I can get a cheap one? I need the 22mm one for a z1 crank.
Also what set ups have people made for the actual starter itself? I don't have the money to dish out for a pre made one.
2001 ZRX 1200
1973 z1 900
- racer54
- Thank you received: 114
05 Apr 2010 17:41 #358600
by racer54
Replied by racer54 on topic Dragbike remote starter?
Here's a link to one from Schnitz Racing.
www.schnitzracingstore.com/catalogs/cata...25866&showprevnext=1
They show up on E-Bay fairly regular so keep an eye out for one on there but they generally go for about the price of a new one. If I'm not mistaken, you can melt the aluminum off the Z1 alternator rotor and what you have left is basically a starter nut. As for a starter, you can use just about any starter you want. Most use a big Chrysler starter or any gear-reduction starter. I have used ones off a mid-90's Dodge/Plymouth mini-van. Just find one in good shape. Take off the bendix and weld a 1 1/8 socket(I prefer the deep socket but some use regular socket...in 6-point style) onto the shaft. Some run starter as is where socket will jump out when button is hit but others modify the bendix drive by extending it and welding in out position so it doesn't jump out at hit of momentary button. To do that you have to take starter apart and modify it though.
- will61310
- Thank you received: 6
05 Apr 2010 17:51 #358603
by will61310
...1980 LTD 1000...
Replied by will61310 on topic Dragbike remote starter?
Could a battery powered impact gun be used as a cheap alternative??
...1980 LTD 1000...
- z1kzonly
- Thank you received: 540
05 Apr 2010 19:24 #358634
by z1kzonly
Replied by z1kzonly on topic Dragbike remote starter?
Chrysler car starter, big block 383 or 440.
They have a gear reduction.
Nut 22M from the machine shop, a socket from Sears tool store.
A piece of aluminum plate.
A little welding and your good to go.
With 1, 12 volt car battery.
I never had over 12.5 compression.
- gvsu141
05 Apr 2010 21:45 #358649
by gvsu141
2001 ZRX 1200
1973 z1 900
Replied by gvsu141 on topic Dragbike remote starter?
Thanks for the input! I will do some searching on ebay to see what I can come up with.
2001 ZRX 1200
1973 z1 900
- APE Jay
- Banned
- Thank you received: 58
05 Apr 2010 23:15 #358653
by APE Jay
Replied by APE Jay on topic Dragbike remote starter?
You can order the nut directly from the manufacturer.
kzzone.com/starterplates.html
- racer54
06 Apr 2010 17:06 #358839
by racer54
I should have looked at your site also.It would be good to order from Jay...after all...he helps support the site. Thanks Jay.
