adjusting the ape?
- scubarod
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- scubarod
- 893cv
- Thank you received: 15
1980 kz1000 LTD
1978 Z1R
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- TeK9iNe
- What did you do!?!
- Thank you received: 28
if you over tighten the cam chain tensioner you will cause all kinds of problems like kinking of the cam chain increased wear of the crank and cam sprockets and increaased wear on sliders and idlers do it like ape say's get the motor to tdc on no.1 then spin the tensioner in until you make contact then back off a 1/4 turnand lock down if its a fresh motor or cam chain you will have to readjust fairly soon,don't attempt this while it is running.do it like ape says and your motor will live along time do it any other way and you will be replacing a lot of very expensive componets in a very short time,.
ABSOFRIGGENLOUTELY!
Overtightening to get rid of a sound is perposterous. If your bike is getting stuck between gears, its because your not making a smooth hard shift, or things are just worn down.
You should be shifting at greater than max advance = 4000 +
Take the valve cover off and check all your valve clearances and chain for wear.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- scubarod
- scubarod
