KZ440 Clutch issue
- Dustin_J
04 Apr 2010 16:16 #358417
by Dustin_J
KZ440 Clutch issue was created by Dustin_J
I'm bringing a 1980 KZ440A1 back to life and I'm having some clutch issues. When I pull the clutch lever in, I get very little resistance and it doesn't seem to be disengaging the clutch at all. The only resistance seems to be from the clutch release spring at the end of the cable. I took the cover off the left side and cleaned, greased, and adjusted the clutch release and clutch cable to no avail. The next step after that was to take the cover off of the right side and take a look, but the nut at the end of the crankshaft that holds the ignition advance wasn't cooperating. Does it seem like I need to get into the clutch itself, or is there something I may be missing with the clutch release? If I need to take a look at the clutch, do you have any suggestions for getting the crankshaft nut off the end?
Thanks for any advice. I'm new at this and this board has been a great help already, but I'm a bit stuck for now.
- flht1997
- Thank you received: 2
04 Apr 2010 17:00 #358423
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic KZ440 Clutch issue
i think on the later 400/440's when you adjust the clutch bottom out the handle adjustment and the cable length adjuster. then at the engine you loosen the jamb nut turn the adjusting screw in till you feel light resistance then turn it in 1/4 of a turn and tighten the jamb nut. then adjust the cable length adjuster till you have about an 1/8 inch freeplay at the handle. most bikes on the engine adjustment you back off the screw 1/4 turn but the 78' and newer you tighten 1/4 turn. still check a manual but it is a place to start before you go into the clutch.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
- Dustin_J
05 Apr 2010 13:16 #358575
by Dustin_J
Replied by Dustin_J on topic KZ440 Clutch issue
Yep, it was an adjustment issue. Thanks for the suggestion. I went back through the service manual step by step and it's working. I don't know what I missed the first time, but this took care of it. I got to take it for its first little ride since I got it and had a big old grin on my face tearing back and forth down the alley behind the house. There's still plenty of work to do, but I know it runs and most of the major stuff is functional, so that's a great start.
