What's this noise? Cam Chain?
- Gorham
I have this high pitched noise (like a remote control race car...) coming from my cam area. I checked out some threads about cam noise, but they seemed equated to a 'rattling' of sorts, not this high pitched noise.
I also recently readjusted my valve clearances with new shims. I didn't take the cams out to do so. I kept them on the chain and just lifted them up to get to the shims. I checked the links in the chain & timing before i put it back together. I also tried to adjust the cam chain tensioner, but it doesn't seem to help the noise any. It seems a little tight when i turn the 17mm lock nut to get it to TDC too. What is this noise and how do i fix it?
1980 KZ650 E1
s29.photobucket.com/albums/c277/_ENGINEE...rrent=KZvideo001.flv
- polkat
- Thank you received: 1
- Gorham
If the cam chain is too tight, and my tensioner is automatic, what do i do to fix it?
- MentalMike
- God Bless America!
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
- Gorham
- JR
- Thank you received: 448
Once you get it on the bike, set TDC and then release the side bolt and the tensioner rod springs forward. Then tighten (dont over thighten) the side bolt and then tighten the locknut.
Good luck.... and have patience.
- Gorham
You have to compress it and tighten the bolt on the side before putting it back on the bike. It can be tricky. Start with the tensioner rod out all the way. press it down against a work bench and tighten the bolt on the side. I know. If it starts to come out you have to let it out all the way before you can try compressing again.
Now this makes sense. I'll give it a shot.
Much appreciated.
