giving up
- chris81kz1100
- ditchdriver
1982 kz 550 ltd
Grand Forks, ND
- bountyhunter
- Thank you received: 337
Sounds like the starter clutch is not engaging.I put my 81 KZ1100 all back together after paint and new bars and such. Looks great. started it up and had a very high idle, tracked it down to the throttle cable sticking at the handlebars. Tried to adjust with no avail, messed with the idle screw to see if that was it. Now when I try to start it the starter just spins and the engine doesnt even crank.
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- sft1662
I'm stuck with a 3cylinder kz650... I cant figure iout whats wrong for the life of me, its a total pain in the ass, very frustrating, out of $$$, but we have to just keep plugging along...
1978 KZ650 B2A
- jeffasaki
- Thank you received: 44
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- Bad Dad
Here's what'cha do... turn the key on, make sure the "kill switch" is in the run position, and "push start" that puppy! Ride the thing around, and you will realize that you "need" that bike!
Maybe this will do what Kawickrice suggested, and engage whatever is not engageing, or line up/mesh the starter gear with the ring gear (whatever they're called on bikes)
Don't give up ...
Tony
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- chris81kz1100
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If you rev the bike a little, and the idle shoots up, its likely lean from and air leak, or the carburetor sync is way off.
Did you remove carbs? or play with mixture screws?
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- larrycavan
- Visitor
With bike idling in neutral, turn handlebars fully side to side. If the idle changes, pull the tank and investigate the above listed criteria.
- PLUMMEN
- Thank you received: 104
just walk away for a little bit and approach from a differant angle!
