Sea Foam in crankcase?
  • Galactica
  • Galactica's Avatar Topic Author
02 Apr 2010 15:48
#357990
I have a 76 kz900 that I resurrected last year. Finally got her running really well after syncing the carbs myself ( the Kawasaki shop never got them right for some reason ).
For the heck of it I bought some Sea Foam today. Put 1/2 the can in the gas tank and started her up. The only initial difference was that the choke was not required almost immediately. I did NOT notice any clouds of white smoke at all as some people have experienced.
My questions are:
1. Has any one used Sea Foam in their crank case?
2. What were the reasons and expectations for doing so?
3. What were the results?
Thanks for the input.
Ross
77KZ1000
76 KZ900
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Sea Foam in crankcase?
02 Apr 2010 16:25 - 02 Apr 2010 16:28
#357992
like it loosenes sludge???...
i did it after reading on here for a while...half a bottle in the tank and half in the case...drove it short 10 mile runs to work and back and changed it to new oil /filter after 30 miles or so...the only thing i noticed was that the shifts were crisper and engaged solid,right after putting it in...it drove "tighter" imo....but that could be a placebo effect......either way it felt good knowing i mighta washed some 1970's crud out....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 02 Apr 2010 16:28 by trianglelaguna.
  • bountyhunter
  • bountyhunter's Avatar
02 Apr 2010 16:37
#357998
Yes, I have thrown maybe four or six ounces of seafoam into the oil a couple of hundred miles before I change it to get a good removal of crud when I drain the oil.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
02 Apr 2010 17:39
#358010
I add seafoam to the crank case. Roy
  • Galactica
02 Apr 2010 20:28
#358045
Thanks for the input guys. I was a little leery of putting an addative in the oil. I'll give it a try.
77KZ1000
76 KZ900
  • sft1662
  • sft1662's Avatar
02 Apr 2010 21:19
#358051
I thought that seafoam was kerosene based :huh: ??? Wouldn't this be bad to mix with oil just like its bad if gas gets mixed with oil? I'm sure it might help clean sludge, but so does gas... I might be wrong here, but I dunno, kinda would worry me...
1978 KZ650 B2A
  • otakar
  • otakar's Avatar
02 Apr 2010 21:20
#358052
I used to use Sea Foam in the crank case all the time. I would add about 4oz every two weeks or so. It cleans the system pretty well and evaporates after a few hours of running. This is why I switched to "Rislone". It will not evaporate and you do not have to keep on adding it. I mix it about 4:1 with my oil and it keeps the system clean all the time.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Unconcerned
  • Unconcerned's Avatar
02 Apr 2010 22:21
#358058
Seafoam specifies right on the can that it's good to use in the crankcase and a lot of people do add it to the crankcase oil. When to add seems to be debatable (Thou the website does have it's own "When to add/change instructions") with plenty of people finding it leery to add seafoam to the oil earlier than 10 km before an oil change and don't drive anywhere while other people add it quite some time before hand and run it like normal oil. I would be most worried about how the engine and transmission/clutch share the same oil. Seems plenty of people do use it thou, if it does help with shifts then maybe I'll give it a try too, sometimes the bike doesn't quite grab the next gear as easily as I'd like it to
  • Old Man Rock
  • Old Man Rock's Avatar
03 Apr 2010 05:55
#358090
This concept has no effects on the clutch friction plate composition?
What about rubber seals?
No harm to stock idler timing components (plastics)?
Interesting, never thought about sea foam in the cases....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • djturnz
  • djturnz's Avatar
03 Apr 2010 06:51
#358105
In my experience, you'll only get smoke by adding it directly to the intake. On my truck, you let the brake booster vacuum hose suck it in until it stalls, leave it off for a couple minutes, then start the motor and let it idle for 15 minutes or until the smoke stops. Be ready to change your plugs, it can fowl them up.
I don't know how you'd do this on a bike with carbs, unless you spray it right in the carb throats.
1982 KZ750 (4) LTD
  • otakar
  • otakar's Avatar
03 Apr 2010 07:06
#358110
I use "Mopar combustion Chamber Cleaner" for this. It coms in a spray can and foams up like foamy engine cleaner. I heat the bike up and remove the spark plugs one at a time. I spray the Cleaner into the plug hole until it comes out the hole and quickly replace the plug. I than let the bike stand until morning, at which time I take it for a spirited ride. I than repeat the procedure again. I do this a couple of times a year. It keeps the chambers and valves squeaky clean.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
03 Apr 2010 07:07
#358112
This is what it looked like inside the bike after I took it apart to install the new top end.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
