Will a shaft motor work to change to chain?
- terry s
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 797
feel free to correct me if i am wrong.
- kaw-62046
- Splandman
i was under the impression that you could change the shaft drive output shaft to a chain drive output shaft and get the appropriate cover's to match the chain drive then you would basically have a mk-11 engine.then you could sling that engine into any kz that took a 900 or non-j 1000 engine and roll.
If you were going to do this could you use a custom swingarm and use the rest of the shaft drive bike so that the bike looks like a MK-II with a custom arm?
I have an extra shaft drive bike sitting here and can't decide what to do with it.
Current Bikes
1980 KZ1000E
- Krusty_47
1976 KZ900 A4
1980 KZ1000 G1
