- Thank you received: 25
KZ650 Main Bearing Bolts
- T_Dub
31 Mar 2010 15:36 #357524
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
KZ650 Main Bearing Bolts was created by T_Dub
Any source for upgraded bolts?
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Tyler
- Thank you received: 92
01 Apr 2010 12:53 #357724
by Tyler
"74 Yamaha DT 400 Enduro
Replied by Tyler on topic KZ650 Main Bearing Bolts
Not specifically for the KZ650. There may be some special order fasteners availalbe but they wouldn't be cheap.
Get a hold fo APE and ask them, if anyone new of upgraded bolts they would. They do carry the cylinder studs and nuts.
kzzone.com/studs.html
Unless they are damaged there realy isn't a need to upgrade them.... or are you doing something crazy to the motor?
- T_Dub
01 Apr 2010 13:05 #357728
by T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic KZ650 Main Bearing Bolts
No, nothing crazy, but I like to replace every fastener. I'll re-use them if I have to. As Carroll Smith used to say, the test for whether you can re-use a bolt is as follows:
Throw it in a bucket of water, if it floats, re-use it.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Tyler
01 Apr 2010 13:10 #357729
by Tyler
Ha! :laugh:
I am with you on that one. When I did my 650 I left no stone unturned, all the fasteners I could replace I did, but not the case bolts for the mains. Just clean them up and assemble with oil. Every single o-ring and seal can still be had for that engine, it gets pricy when you add them up. I still didn't hesitate.
- T_Dub
01 Apr 2010 13:14 #357730
by T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
Yeah, I'm replacing pretty much everything. O-rings are cheap enough, seals not so much.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- DoubleDub
- Visitor
01 Apr 2010 19:49 - 01 Apr 2010 19:57 #357820
by DoubleDub
Replied by DoubleDub on topic KZ650 Main Bearing Bolts
If you find something...let us know! I think Carillo does upgraded bolts to go with their two-piece knife rods (which I believe APEJay stated would be custom order for a 650), but I haven't seen anything about main bearing bolts. Maybe APE or LarryCav know?
Last edit: 01 Apr 2010 19:57 by DoubleDub.
