- Thank you received: 6
My head is done!
- fordtruck
31 Mar 2010 09:19 #357435
by fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
My head is done! was created by fordtruck
I got an email from Pit Stop Performance that my head is shipping out today! With any luck I'll have it by the weekend. I'm three months into this motor rebuild and I'm anxious to hear it run again.
- mark1122
- Keep twisting it
- Thank you received: 109
31 Mar 2010 09:48 #357441
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic My head is done!
I can almost here the veroom veroom, now.
what did u have done to your head?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
- Thank you received: 104
31 Mar 2010 15:55 #357529
by PLUMMEN
Replied by PLUMMEN on topic My head is done!
my head is in need of some serious work also,problem is its connected to the rest of my body! :woohoo:
- otakar
31 Mar 2010 16:01 #357532
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic My head is done!
I keep telling my wife something to that line. :woohoo:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- larrycavan
- Visitor
31 Mar 2010 17:46 #357560
by larrycavan
Replied by larrycavan on topic My head is done!
Just in time for some good weather!
Did you get some nice drop in cams to go with it or what?
Larry C:)
Larry C:)
- roy-b-boy-b
- Thank you received: 103
31 Mar 2010 19:27 #357581
by roy-b-boy-b
Replied by roy-b-boy-b on topic My head is done!
I know nothing! :blink:
- fordtruck
31 Mar 2010 22:18 #357620
by fordtruck
Replied by fordtruck on topic My head is done!
mark112, I had the head rebuilt. New guides, seals, surfaced, clearanced for bigger cams, and heavy duty valve springs installed. Also had him do a stage 1 port job on it.
Larry, sticking with stock cams for now. I'm way over budget as it is!!
I'm expecting the head to arrive Friday or Saturday. Sunday is my birthday, so I can't think of a better present than to hear it run! May not happen that quick, but that's ok.
- larrycavan
- Visitor
02 Apr 2010 19:35 #358036
by larrycavan
Take your time putting it together.
Make sure the cam chain is on the crank sprocket.
Put the bike on the center stand or level it up if you don't have a center stand.
After you install the cams, turn the motor over 2 complete revolutions and check your timing marks again. They should like right back up.
Put oil on your cam cap bolts !!!!!!!!!!!
When you install the dowels for the cam caps, make sure the tapered part is up and put the dowels in the head, NOT in the caps.
After you fire the motor up, heat cycle it one time, then let it get stone cold and torque the head again. The nuts get loose real quick. Do it that way and you'll avoid head gasket leak issues.
Lastly..... ENJOY it and ride safe
When you want some nice cams for it, holler and I'll hook you up with some cams that you'll love and keep shim on top valve adjustment.
- fordtruck
03 Apr 2010 13:42 #358194
by fordtruck
Larry, that's great advice that I will follow! Unfortunately my head hasn't arrived yet. Oh well, I've waited this long, a few more days won't kill me.
