ID cams in kz1000
- rstu
30 Mar 2010 18:35 #357324
by rstu
77 kz1000
2001 Aprilla SL1000
ID cams in kz1000 was created by rstu
I've got a 77 kz1000 with a 78 motor. Trying to figure out what the last owner modified. Can I ID the cams without taking them out or is it time to up my skill set!
77 kz1000
2001 Aprilla SL1000
- otakar
30 Mar 2010 18:37 #357326
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic ID cams in kz1000
You at least have to be able to see the cams, so at minimum you will have to remove the cam cover.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
- Thank you received: 2
30 Mar 2010 18:49 #357329
by keith1
Replied by keith1 on topic ID cams in kz1000
pull the cam cover...i can tell you andrews marks theirs with "andrews " and the model # on the end of the base shaft....not sure on the others.....post up some pics..
- PLUMMEN
- Thank you received: 104
30 Mar 2010 20:21 #357354
by PLUMMEN
Replied by PLUMMEN on topic ID cams in kz1000
they look like theyre between .325 and .435 from here! :woohoo:
- rstu
