- Thank you received: 35
Cam timing question
- moneypit
30 Mar 2010 17:12 #357267
by moneypit
2-76 kz900
St Paul MN
Cam timing question was created by moneypit
Put the head back on and after i finished I noticed in the manual that I should have loosened the cam chain tensioner. Timing was dead on 28th pin right where it should be Am I going to have to redo this I havent moved any thing just incase Thanks
2-76 kz900
St Paul MN
- keith1
- Thank you received: 2
30 Mar 2010 17:20 #357269
by keith1
Replied by keith1 on topic Cam timing question
yank it completely and re-check.....save yourself the trouble i went through.......when you pulled that chain up to set cams, you could have misaligned the chain and roller......at the very least with the valve cover off, put a flashlite in there and confirm correct contact with tensioner roller......
- moneypit
30 Mar 2010 17:24 #357272
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Cam timing question
Everything looked good and pulling on the chain I could tell it was on the crank sprocket but I probably should just to be sure son of a &*@%!
2-76 kz900
St Paul MN
- keith1
30 Mar 2010 17:44 #357280
by keith1
a lot cheaper to be sure....been there....my ass still hurts from parts buying.....
