Motorcycle accelerates then dies HELP
- robert1083
30 Mar 2010 15:32 #357242
by robert1083
Motorcycle accelerates then dies HELP was created by robert1083
Hi, I wanted to take my bike out for the first time this year. I drained the cards and added seafoam to the tank for the winter. I warmed the bike up, and upon acceleration, the bike keeps dying. I was told that the carbs had been cleaned out so I don't know what going on.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
30 Mar 2010 15:47 - 30 Mar 2010 15:48 #357245
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Motorcycle accelerates then dies HELP
Would help some to know the model/type of carbs...
I would say make sure you let it idle good for a few mintes off choke, and just try to rev it.
When you added seafoam to the tank, did you run it for 5-10mins to get seafoam all thru carbs/engine?
Go slow and start smoothly... if the problem still persists, it could be some kind of carb related blockage.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 30 Mar 2010 15:48 by TeK9iNe.
- MFolks
- Thank you received: 540
30 Mar 2010 16:03 #357249
by MFolks
Replied by MFolks on topic Motorcycle accelerates then dies HELP
Tried it with the gas cap open? you may have blockage of the gas tank's vent.
