will ltd 750 engine fit in my 79 kz 650 frame?
- kzbellrider
29 Mar 2010 18:41 #357066
by kzbellrider
will ltd 750 engine fit in my 79 kz 650 frame? was created by kzbellrider
i have a 79 kz 650 im looking for some more power out of her i have a 1980 ltd 750 motor will it fit in my frame and will i be gaining anything from doing this?
- kzbellrider
29 Mar 2010 18:44 #357067
by kzbellrider
Replied by kzbellrider on topic will ltd 750 engine fit in my 79 kz 650 frame?
i also have a spair 650engine i plan on doing a 810 kit but dont know if i should use the 650 lower end or just use the 750 i have
- anarki650
- Thank you received: 5
29 Mar 2010 18:58 #357070
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic will ltd 750 engine fit in my 79 kz 650 frame?
The 750 will drop right into the frame. They share the same cases and swap a lot of parts between the two motors. You'll gain 100 cc, and like the old saying goes...there's no replacement for displacement!
09 Kawasaki ER6n
Omaha NE
- Bluemeanie
- Thank you received: 14
30 Mar 2010 05:49 - 30 Mar 2010 06:03 #357158
by Bluemeanie
Replied by Bluemeanie on topic will ltd 750 engine fit in my 79 kz 650 frame?
Other than bore size, they are the same exact motor. The only difference is that it will say "738" instead of "652" on the side of the motor!
"I also have a spare 650 engine I plan on doing a 810 kit but don't know if I should use the 650 lower end or just use the 750 I have."
Using the 650 would require using a Dremal tool to clearance the cases for the larger cylinder block, then the big bore kit and the 750 head if (only certain year 750 heads work) it has the provisions for using the 650 cam chain and idlers. Using the 750 only requires the big bore kit. A lot less work and hunting down the right head.
Here is an article that explains what head is needed...
Last edit: 30 Mar 2010 06:03 by Bluemeanie.
